by Cary Winch » Thu Feb 02, 2006 9:28 pm
Jim,
On the Camp-Inns we bend the rear rollpan skin in about 1.25" and then up a half inch. The countertop then sits over that and overhangs that edge a tad bit. That creates a splash area that if water where sprayed in the hatch gap it would be stopped under the lip of the counter and run back off the rear rollpan skin. The hatch frame stops above the countertop and there is a flange that hangs past to cover the area in question when the hatch is closed. The flange is basically the aluminum hatch skin hemmed over a piece of 1/8" panneling then attached to the bottom of the hatch frame. A rubber seal goes over that to keep dust from getting sucked in the galley.
Clear as mud?
Kerry probably has a good idea about seeing one. We have some customers south of you in Georgia but nothing too close. Traveling some time soon? Maybe there is someone you could hook up with along the route.
Cary
