toypusher wrote:True, it does. You can take the two crossmembers at that joint and put them lengthwise inside the side rails to joint the two halves together and do away with the folding part. You then use a wooden crossmember to replace the two that you used. Check out the 'Generic Benroy Plans' at the top of the page. The trailer used in the plans is not the HF, but the principle is the same.
