frederick wall to floor
![Post Post](./styles/prosilver/imageset/icon_post_target.gif)
What glue do you guys use on this joint? PL or TB? Also, I see where Tony does a pocket hole looking screw from the top, any problem with running screws up from the bottom?
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
martymcfly wrote:What glue do you guys use on this joint? PL or TB? Also, I see where Tony does a pocket hole looking screw from the top, any problem with running screws up from the bottom?
