steel door frames
steel door frames
Postby critter » Thu Feb 09, 2006 5:14 pm
hey all,
has anyone tryed making their door frames out of steel angle iron.i wuz thinkin i would try if no one else did but am willing to learn fro someone elses mistake.i can weld steel but not aluminum.i figure i could weld &grind it smooth to make it seal.any ideas good or bad?thanks :roll:
critter
critter
critter
Images: 54
Postby PaulC » Thu Feb 09, 2006 5:35 pm
Critter, I purchased pre-made aluminium(aluminum) doors that had an external frame as part of the build. It sure made life easier and negated the need for a piano hinge on each door. The only thing was the total cost $> . My next one will have the more traditional door albeit with a frame as you are suggesting but with aluminum. No welding, prefab and plenty of sealant.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby alaska teardrop » Thu Feb 09, 2006 6:10 pm
Critter - Yes, I use 1/16x1x1 tubing to frame the door & trunk. Different, but light, simple & strong. Unfortunately, no detailed photos. Sketches if you want the concept. Fred :snow
alaska teardrop
Postby Gaston » Thu Feb 09, 2006 11:40 pm
the hatch on my trailer will be formed 1"sq tube . also useing it for the roof rafters/spars.I need to keep things "thin" so I'm useing the steel tube instead of wood in these areas.
The difficult we do now... the impossible takes a little longer
Gaston
Images: 98
Postby Erik-the-red » Fri Feb 10, 2006 12:21 am
I built my whole teardrop out of 1 x 1-inch square tubing (except for the frame itself of course). If you can weld, it is certainly the way to go. My trailer (also with steel sheeting on the outside) could survive a nuclear holocaust.
Erik-the-red
