seahorse wrote:Thanks Madjack,also I was reading a previous post, and checked your www. and decided to make my hatch the way you did. NO SPRINGBACK.....Nice job
madjack wrote:..you run the Al to the edge and screw down thru it.............................
The secret in building a hatch with no springback is to think it out and use common sense. I believe my hatch is bigger than Madjacks (maybe not) and when it was completed, I ended up with the same results. Building it basically the same way.seahorse wrote:Thanks Madjack, also I was reading a previous post, and checked your www. and decided to make my hatch the way you did. NO SPRINGBACK.....Nice job
toypusher wrote:What's the thickness of your AL?
