Can you spar varnish over the staples in the outer skin?
Hi everyone,
Long time reader, first time posting. I'll be posting an introduction thread with my build but wanted ask a question that I can't seem to find an answer to. On my outer skin I used 1/8" plywood with PL construction adhesive and 9/16" staples. I'm doing aluminum over the whole outer skin but wanted to go an extra step and spar varnish the entire outside plywood. My question is varnishing over the staples and will that waterproof them as well? Only other thing I know to do would be to take them out but there are hundreds and hundreds of them and would be a huge pain and I like the added holding power even though I"m sure it is not needed with the 8X PL adhesive I'm using as well. Never used spar varnish before so was just wondering if it is thick enough to cover the staples that sit flush on the surface of the outer skin, thanks for any guidance.
