cracker39 wrote:Ira, have you had your trailer weighed? If not, I would load it for camping, and get it on a scale. Or, you could use the bathroom scale technique to get a fairly accurate weight. Then, put the coupler on the scale to see what it weighs. If the tongue weight is 10%-15% you should be OK. But, looking at the picture of your TD, I'd say you have at least 10%, and probably 15% or more if that tongue box is as heavy as it looks. With a TD, I wouldn't think having a tongue weight of 20% wouldn't be a problem, as long as it doesn't exceed your hitch limits. With the axle as far back as you have yours, it should tow like a dream.
Okay, so is this a plan, Dale? And here are my questions:
1) I have a weigh station right near my boatyard, so that's easy.
2) I get a standard scale and lower the coupler onto it. Correct? (I guess I have to use my bottle jack to bring it back up to extend it back up.) Or can you ALSO do this at a weigh station? Actually unhitch it and just weigh the tongue?
3) My vehicle's hitch limit isn't an issue--long-bed Silverado truck.
4) My tongue box, I think, isn't as heavy as it looks--especially when you consider nothing is going to be stored in there besides paper/blanket goods. Additionally, I have no heavy cabinetry going into the front of the cabin, just a shelf, so aside from the AC, not much weight there.
5) Finally, let's say I go NUTS with galley weight, and it's the OPPOSITE. That my tongue weight is only 9%. (Ain't saying this is going to be the case, just asking.) I now want to store some stuff forward in the cabin, right? To avoid terror and death as Junkman describes?
It's not like once everything is designed and built, that you can change this. So once all is done, first get those raw total and tongue weights, and take it from there.
