Construction Adhesive is a bad sealant
Postby edgeau » Fri Jan 25, 2019 5:42 am
Just a word of warning if you get tempted to run a bead of construction adhesive as sealant because you already have it in the caulking gun etc. It worked for about a year for me before cracking. It is just not flexible enough. Fortunately I only experimented on a small section and have now redone it with the good stuff (Sika flex pro)
Sent from my Pixel using Tapatalk
edgeau
Re: Construction Adhesive is a bad sealant
Postby Tomterrific » Fri Jan 25, 2019 8:00 am
I would say construction adhesive is a bad caulk. What CA were you using? PL 3x and 8x are urethane based as is Sika Flex. Put PL between joints and it is nicely gap filling so seals joints just fine. I used and liked PL for its strength and gap filling since I am NOT a fine woodworker. I tooled the squeeze out with a finger and used poly urethane caulk over the edge.
Tt
Tomterrific
Postby tony.latham » Fri Jan 25, 2019 10:39 am
...a bead of construction adhesive as sealant...
Liquid Nails?
T
Postby swoody126 » Fri Jan 25, 2019 11:56 am
ADHESIVE ≠ SEALANT
unless it is a fillet of thickened epoxy...
sw
swoody126
Postby edgeau » Sat Jan 26, 2019 3:16 am
Tomterrific wrote:I would say construction adhesive is a bad caulk. What CA were you using? PL 3x and 8x are urethane based as is Sika Flex. Put PL between joints and it is nicely gap filling so seals joints just fine. I used and liked PL for its strength and gap filling since I am NOT a fine woodworker. I tooled the squeeze out with a finger and used poly urethane caulk over the edge.
Tt
Yes bad caulk is more accurate. I was using liquid nails. And where it is glueing two pieces together it is just fine. It was where I used it in a way that it was not designed for that it failed....
edgeau
Liquid Nails?
T
Yup
edgeau
Postby tony.latham » Sat Jan 26, 2019 11:08 am
edgeau wrote:
Liquid Nails?
T
Yup
I'm an advocate of PL Premium. I've always got a tube stuck in a gun laying in the shop. Haven't bought a tube of Liquid Nails in years.
Here's a good reason to avoid the LN stuff:
:frightened:
Postby Dan242 » Sat Jan 26, 2019 4:53 pm
I used the PL glue on my woody, seems to be holding just fine. I can see where LN might need a back up though
Dan242
Images: 25
Postby edgeau » Sat Jan 26, 2019 10:15 pm
tony.latham wrote:
edgeau wrote:
Liquid Nails?
T
Yup
:frightened:
Interesting video
edgeau
Postby aggie79 » Mon Jan 28, 2019 10:28 am
swoody126 wrote:ADHESIVE ≠ SEALANT
sw
Au contraire. I used copious amounts of this (expensive) adhesive/sealant to adhere and seal aluminum sheeting, trim, hardware, etc. in my build:
https://multimedia.3m.com/mws/media/1198187P/3m-marine-adhesive-sealant-4200fc-white.jpg
