Well I had decided to take the easy route to fix my trailer issues and went and bought some PPG Gripper paint and decide to paint over the Raptor liner. Well once I bough the paint and pulled my trailer out to wash it I looked at the cracking and it had gotten worse. Like way worse. To the point you could grab the first layer of Baltic birch and just pull off the layers in huge pieces. See pic below. So I decided that maybe i would just pull off the first layer of Baltic birch but that didn’t go so well either.
![Image](https://uploads.tapatalk-cdn.com/20190312/37f60dcc8da17b2ff3c52272cbd3c697.jpg)
So then I made the decision that I’m going to just pull the entire outer skin off the entire trailer. So now I have to do some real work. Finding all the screws was made much easier with a good strong magnet. And once found I’d go after the area with the claw of a hammer to expose the screw head. Took about 4hrs with my two boys helping to do this. It was no easy task. But I want to do this right this time so I don’t have to do it again.
![Image](https://uploads.tapatalk-cdn.com/20190312/b42c03ed08cf5435bcc7b196a6080c87.jpg)
It’s going to be an all day project to strip this entire trailer but I think it’s the right way to go about this.
![Image](https://uploads.tapatalk-cdn.com/20190312/4ecdd84b3e246151ece48642a605266b.jpg)
So I have a few questions. I hate to say I need to cheap out on this but I really do need to finish this the least expensive way possible. I would love to fiberglass (even though I really don’t know how) or use aluminum or sheet metal but I’ve already put to much money into this and need to somehow find the best way to seal the wood and just get it done.
I’m really considering the PMF method of finishing this. Can someone please educate me on the best way to finish this off that isn’t going to be super expensive? If doing PMF do I need to treat the wood first? If so what with? Seems like I’ve seen people just paint the exterior with paint then lay on the fabric drop cloth and then paint again over that. Will this work or do I need to do more prep work first?
Also I originally skinned my outside of my trailer with 1/4” Baltic birch. Should I use the same again or go a different route? If different what should I use?
Sent from my iPhone using Tapatalk Pro
