Tom Horn wrote:I have been looking at all the different type of construction techniques for doing the walls. I was originally planning on just doing the 3/4" plywood framing method with 3/4" insulation in the wall. Well I got to thinking and that's not usually a good thinghow about making a template. Then taking strips of Maple and bending them around the template to create the wall edge. In my thinking this should make a stout wall design and would also allow me to use a full inch of wall insulation instead of 3/4 inch in my walls. I am planning on making the walls 1.5 inches thick. So I would have 1/4" cedar strips on the exterior and 1/4" for whatever I choose to use for the interior. At this point I am thinking cedar inside and out. I was curious if anyone has tried something similar or am I opening up a can of worms that I don't want to deal with if I tried this idea.
Pmullen503 wrote:If I understand, you want your walls to bow out? Depending on how much curve you have, you can build that curved beam from several thinner plys of wood glued together. I would use white oak or Ash rather than maple. Make one wide curved piece and rip saw it in half to get a matched pair
Introducing curves into the design makes it stiffer than a flat sided box so you should be able to build it lighter .
...instead of wasting all the plywood cutouts...
In my thinking this should make a stout wall design...
tony.latham wrote:...instead of wasting all the plywood cutouts...
Let's get this on the record: There is no waste --or scrap-- wood. It get's used.(And I assume you'd use your form for your arches for some other project down the road.)
Since you're a bower, you can pull this off. I'm wondering how you will join the other members of your framing to your arches?
With my first teardrop, I followed Steve Fredrick's manual and used his "stick" framing method.
I think it took me two days to create two frames with all the joints. (Most of them were with biscuits.) The pine was cheaper than three sheets of 3/4 CDX ply but the labor wasn't worth it.In my thinking this should make a stout wall design...
How will you join the bulkheads into your sidewalls?
If you go this route, make sure you take plenty of pics. I enjoy watching unique builds come together.![]()
