Cutting Door Openings
Postby powelly78 » Wed May 08, 2019 7:40 pm
Hi all,
I wrongly put my question in the build journal. - its had many views and no replies.
I cut a template out from a Kit profile I ordered online. -
I"m using pre made doors though, and I want to get the template right before I use a flush trim router to cut the pattern onto the good (expensive) plywood.
So, I'm really not happy with my first cut out on the door especially on the corners( I used a jigsaw ) , and I am really glad I am doing some testing templates on the crap plywood.
Does anyone have any tips on cutting the corners for the door cut out? the corner of these doors is actually a little proud of the straight area - when they bent the curves in the factory it pushed the curve out a little proud
And since these doors don't have an internal trim ring to hide any of my unscrupulous work........Id like to get it right.
I'm thinking of a tracksaw or circular saw with guide rail, for the straights, and maybe a router with a circle jig? ( cutting out the circles before the straights obviously )
What does everyone else use to cut the corners?
Any advice greatly appreciated. 158113158112158110158114
powelly78
Images: 40
Re: Cutting Door Openings
Postby tony.latham » Wed May 08, 2019 7:52 pm
The norm would be to make a template out of 1/4” ply and use either a router bit with a top bearing or a spiral upcut bit with a guide bushing. If you close the latter keep the cuts limited to about a 1/4” depth.
T
Postby powelly78 » Wed May 08, 2019 8:29 pm
Thanks Tony,
I had not considered a separate template from the template, I'll use a compass to draw the arc, and maybe a router table to cut the template. :thumbsup:
powelly78
Images: 40
Postby Pmullen503 » Wed May 08, 2019 9:08 pm
powelly78 wrote:...............
That's what I did with mine. Still have to clean it up with sanding. (I was not trying to save the cut out for the door.)
Pmullen503
Images: 67
