Steve Frederick method of hatch??
Postby mwright3582 » Fri Jul 26, 2019 8:48 pm
So built my frame walls out of 1 x 4 material. I got the cut for the roof splines. But the cut for the hatch I am confused.
I am using 3/8” plywood on the outside, then aluminum over that
Cutting the pieces from each side not sure how to cut that the “Dan rambles” videos show him marking a it 2” and the curve at the hinge, but besides hoping you can cut with a jigsaw that perfect is there a better way?
Also
Questions
Do I put the 3/8” skin on before cutting these hatch pieces?
It seems he puts an 1/8 piece on the inside as well?
I got the Frederick Manuel and watched the dan ramble you tube. But it’s like both skipped Thur this so fast
Thanks for any help
mwright3582
Re: Steve Frederick method of hatch??
Postby kayakdlk » Mon Jul 29, 2019 6:53 pm
I agree the manual cover most but was not super clear on the hatch, so if you go to his web site and look at his builds especially the Lil Dinners #1 5th page (click next 5 times, or see link below) he shows cutting the hatch out with a jig saw. I did this on my build (see page 2) and just went slow, it doesn't have to be perfect just follow the line using a fine tooth bit, and don't use much forward pressure or you will not cut straight down through. Yes the sides are already skinned inside and out. I used 1/8 Baltic birch skins inside and out but you can use whatever you want depending on the weight you are going for.
http://www.campingclassics.com/diner5.html
Also check out the Galley page for the same build as it shows building the galley walls and gussets for the hatch
http://www.campingclassics.com/diner7.html
kayakdlk
Images: 392
Postby tony.latham » Tue Jul 30, 2019 3:59 pm
Don’t scrimp on the jigsaw blade. Bosch or Starrett (sp?) Go slow with no side pressure and you’ll be fine.
https://i.imgur.com/ewkPjEy.jpg
And yes. Have both sides of your walls skinned.
T
Postby nicoleandkyle » Tue Jul 30, 2019 4:58 pm
I'm not sure if this will help, but today I watched all of the Dad Rambles YouTube Hatch videos to get a good understanding of what is to come, as I'm about to cut the hatch ends hopefully tonight or Thursday. I made a few pages of notes, and they are actually edited specifically to my build. Here they are in case they might help you or others:
https://docs.google.com/document/d/1siO ... p=drivesdk
Sent from my SM-N950U using Tapatalk
nicoleandkyle
Postby mwright3582 » Sun Aug 11, 2019 9:34 am
Thank you for the help. I got the cuts done pretty happy with it.
mwright3582
