Any reason not to use boat windows?
Postby sarahem » Mon Aug 26, 2019 2:21 pm
I am trying to keep the build as cheap and simple as possible. I was looking up camper windows and actually found a lot of boat windows that are the right size and price. Any reason not to use them? :)
sarahem
Re: Any reason not to use boat windows?
Postby tony.latham » Mon Aug 26, 2019 2:36 pm
sarahem wrote:I am trying to keep the build as cheap and simple as possible. I was looking up camper windows and actually found a lot of boat windows that are the right size and price. Any reason not to use them? :)
As long as they open and are screened.
Postby Squigie » Mon Aug 26, 2019 2:53 pm
I had considered the same, but can't find anything suitable locally.
Keep in mind that a lot of boat windows / port lights have thicker glass than most RV / camper applications. So they generally weigh a bit more. The difference wouldn't be noticed in most builds. But if you were building an ultra-light with big windows, it might be something worth paying attention to.
Squigie
Postby sarahem » Mon Aug 26, 2019 3:02 pm
Squigie wrote:I had considered the same, but can't find anything suitable locally.
Amazon actually has a few options that would work for me! Around $30. The weight is something we are minding but I think two very small windows will be OK!
Sent from my Pixel 2 XL using Tapatalk
sarahem
Postby Tomterrific » Mon Aug 26, 2019 4:36 pm
Make sure it is a slider or if an awning, opens out. Boat windows open in, I think.
Tt
Tomterrific
Postby GTS225 » Mon Aug 26, 2019 5:51 pm
You might want to investigate marine deck plates.
https://www.google.com/search?hl=en&biw ... FMQ4dUDCAY
8 inch is about the largest I've seen, so it might be a sacrifice to use them.
I have in mind using a black one inside, and a white with clear center outside, with a piece of screen sandwiched between. In that way, I can remove the centers of both for passive venting, keeping the bugs out. I can also keep the clear outside in place, making it a window, and with the black center on the inside, I can sleep in, in total darkness if I want to.
Just a thought.....Roger
GTS225
