Page 1 of 4
Attached aluminium to wood? How?
PostPosted: Sat Nov 23, 2019 1:28 pm
by Scubieman
Wondering how to attach aluminium to wood? Not sure what adhesive to use? I used liquid nails deck and subfloor for gluing wood to wood.
Thanks
Sent from my Pixel 2 XL using Tapatalk
Re: Attached aluminium to wood? How?
PostPosted: Sat Nov 23, 2019 2:50 pm
by Sparksalot
Don't do it. The different expansion rates will resulting in "oil canning" of the aluminum skin when the sun shines on it.. Using trim pieces at the edges and openings will hold it in place.
PostPosted: Sat Nov 23, 2019 3:57 pm
by Scubieman
So what do I do? A silicone and the edges?
PostPosted: Sat Nov 23, 2019 5:01 pm
by tony.latham
Don't use silicone. It's (mostly) corrosive to aluminum and nothing sticks to where it has been used. Used a good poly sealant such as OSI.
Dry fit the trim and then lay a bead of sealant inside the sealant and re-attache.
:thinking:
PostPosted: Sat Nov 23, 2019 5:08 pm
by Scubieman
Only attached on edges? Otherwise it's free floating?
I only have Menards and Amazon where I am
PostPosted: Sat Nov 23, 2019 5:15 pm
by tony.latham
There are two camps. I fall into the free-floater group. Attaching a 10' piece of aluminum sheet with contact cement sounds like a good way to have a bad day.
It's attached along ever edge with trim except under the hurricane hinge.
PostPosted: Sat Nov 23, 2019 5:17 pm
by Scubieman
Wow. I thought it should be glued and screwed in more spots. I guess I'm wrong. Only the edges
PostPosted: Sat Nov 23, 2019 5:31 pm
by tony.latham
Scubieman wrote:Wow. I thought it should be glued and screwed in more spots. I guess I'm wrong. Only the edges
Polyurethane the wood before you sheath it.
T
PostPosted: Sat Nov 23, 2019 5:33 pm
by halfdome, Danny
Like it was mentioned there are two camps on the subject.
As a cabinetmaker using contact cement is a no brainer.
I’ve used it on the 6 teardrops I’ve made and a friend has done the same on 44 of the teardrops he has made.
To date no delamination or any other problems and mine have been in 103 degrees in full sunshine ☀️.
Contact cement is basically rubber and will not rip your plywood.
If you choose to use contact cement make sure you do a total coverage on the plywood and the scuffed up aluminum.
I use Wilsonart spray grade contact cement that is available in a 5 gallon bucket but it’s also available in 1 gallon.
Use a low nap roller and pan to apply.
I sand the backside of my aluminum with a 5” DA sander using 80 grit sandpaper.
:D Danny
PostPosted: Sat Nov 23, 2019 5:34 pm
by Scubieman
halfdome, Danny wrote:Like it was mentioned there are two camps on the subject.
To date no delamination or any other problems and mine have been in 103 degrees in full sunshine .
I sand my aluminum with a 5” DA sander using 80 grit sandpaper.
:D Danny
Thanks
PostPosted: Sat Nov 23, 2019 5:52 pm
by tony.latham
I’ve used it on the 6 teardrops ...
Danny is one of those guys that when he "speaks," you should listen.
PostPosted: Sat Nov 23, 2019 5:58 pm
by halfdome, Danny
Your welcome.
When I attach a 10’ sheet I have 2 plywood boxes the equal the height of the wall bottom of the level teardrop.
I then place equal sized strips of wood or dowels that are spaced about 16” to the tacky contact cement on the body.
Make sure they go past the top and bottom of the wall so the aluminum doesn't prematurely stick.
Then I place the sheet on the plywood boxes and tack the center of the sheet to the body.
Then start hand smoothing the sheet removing the strips as I go along.
It’s best to use a metal shear to rough cut the aluminum.
Use a high quality flush trim router bit to trim to the final profile.
Thanks Tony
:D Danny
by Scubieman
My build is goofy. It's taller then 4feet. So I'm putting fascia at bottom then aluminium over that. I'm about one inch too short.
PostPosted: Sat Nov 23, 2019 6:42 pm
by halfdome, Danny
Scubieman wrote:My build is goofy. It's taller then 4feet. So I'm putting fascia at bottom then aluminium over that. I'm about one inch too short.
Here's what I do since my walls are more than 48" tall.
I butt joint the two pieces of aluminum and cover the joint with a 1/2" wide strip attached with the thin VHB tape, works great.
It's a smaller joint at the top.
:D Danny
PostPosted: Sat Nov 23, 2019 6:45 pm
by Scubieman
My joint will be at bottom. Then I can curl over the wood of trailer.
I will out taller trim in. But this is kind of how I want it done.
https://photos.app.goo.gl/s3xZfK3pWjxqiP137
