just makin sure (vent framing)
Postby stjohn » Mon Feb 20, 2006 5:57 pm
vent opening is 14 1/4" by 14 1/4'" correct
THanks in advance Mike
Only he who attempts the ridiculous
Can achieve the impossible
stjohn
Images: 68
Postby asianflava » Mon Feb 20, 2006 6:03 pm
For a Fantastic fan? Then yes. I'm not shure about others but I think it's a generic size. Actually, I made mine 14 1/8 but it's a little tight for the wires.
asianflava
Postby Frank » Mon Feb 20, 2006 6:03 pm
Correct.
Let's go camping!
Frank
Images: 52
Postby madjack » Mon Feb 20, 2006 7:29 pm
..yep and be sure to have about 1.5" of framing around it fasten to ...................................... 8)
Postby mikeschn » Mon Feb 20, 2006 8:56 pm
madjack wrote:..yep and be sure to have about 1.5" of framing around it fasten to ...................................... 8)
Exactly right!!!
Postby Steve_Cox » Mon Feb 20, 2006 9:33 pm
I framed in a 14 1/4" square opening in my roof and ran wires to it a few months ago, but now I can't remember exactly where in the roof it was... Guess I'll just get the router out and start lookin' when the time comes....
:lol: :lol: :cry:
Steve_Cox
Images: 196
Postby Laredo » Mon Feb 20, 2006 11:04 pm
did you use anything steel to fasten the wires to the frame?
A magnetic 'stud finder' might help you locate your vent opening if you did.
Laredo
Postby Steve_Cox » Mon Feb 20, 2006 11:43 pm
Laredo wrote:did you use anything steel to fasten the wires to the frame?
Yup, got a stud finder, that should do the job. At least I know the opening is on the centerline, and aligned with the door opening. Just can't remember which way the darn trailer was facing....
Steve_Cox
Images: 196
Postby kayakrguy » Tue Feb 21, 2006 7:32 pm
Folks,
A question about the vent framing...
How thick a roof/wall can the Fantastic Fans accomodate....is that adjustable for the fans or do you have to order specific fans for specific wall dimensions?
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
Postby Mitheral » Tue Feb 21, 2006 11:51 pm
This kind of thing is why I've been taking build pictures of my projects for the last 15 years. It's really helpful when you want to know exactly where that waste pipe in the wall you had openned up five years ago is.
Those disposable cameras are good for this kind of thing, I've got several thousand in Nikon kit but I'll still use the disposables on construction projects so I don't have to worry about the dust/damage.
Mitheral
Images: 19
Postby Ira » Wed Feb 22, 2006 9:15 am
Jim, I forget what they call it, I think it's called the flange, but yes:
You order the specific size flange for your roof thickness; the fan is the same.
Here we go again!
Ira
Forum Storyteller
Images: 118
