Page 1 of 1
Generic Walls
PostPosted: Tue Feb 21, 2006 6:11 pm
by Gary T
Hey everyone
If I plan on insulating the walls in the generic benroy do I still need to use 3/4" plywood?
I am thinking of using 1/2" ply then straping the walls with 1" and insulating the cavities with foam and then using 1/8" something over top.
I have seen this done on other builds, and assume that the walls are 1/2" thick.
But you know what assume usually means...
Gary T.
ps: Budapest was great, we won a bronze medal, and Borsodi(beer) is great tasting. If I get a pic of the team I will post it.
PostPosted: Tue Feb 21, 2006 6:15 pm
by Chris C
Gary,
1/4" plywood, 3/4" insulation, and 1/4" plywood will do just fine. Just make sure you put 3/4" wood behind areas you plan on fastening things of structure to.
PostPosted: Tue Feb 21, 2006 6:19 pm
by Gary T
Thanks chris.
Just saved me a bunch of cash
G
PostPosted: Tue Feb 21, 2006 6:40 pm
by madjack
Hey Gary, glad to hear that Budapest was a smashing success and that y'all gotta medal and some good beer...Chris has ya steered in the right direction....hope to see that pic soon
madjack 8)
PostPosted: Tue Feb 21, 2006 7:16 pm
by toypusher
Gary,
Check out this build site: Lil Diner by Steve Frederick
Might want to consider buying his Shop Manual too!
Re: Generic Walls
PostPosted: Wed Feb 22, 2006 4:48 am
by bledsoe3
Gary T wrote:I am thinking of using 1/2" ply then straping the walls with 1" and insulating the cavities with foam and then using 1/8" something over top.
Gary, That is exactly what I did. I think 1/4" would be fine too.
The bottom 1" X 3" sits on top of the floor and the remaining ply covers the frame. The screws were removed after the glue had dried. BTW, this is the Generic Benroy profile. More build pic's here. http://tnttt.com/album_ ... SC&start=0
PostPosted: Fri Jun 08, 2007 8:05 am
by SaGR
I'm thinking of doing what bledsoe3 did with his but with 1/8" outside covered with a single layer of glass cloth, probably a 4 harness satin weave since it's clear when it cures.
Overkill? Dunno... thoughts?
