help understanding the best way to seal
i am just about finished with my first teardrop build, i took on this challenge because i wanted to learn about carpentry. i know about being a mechanic and welding however the woodworking has alluded me.
i camp every other weekend in northern Minnesota and wanted something stronger then a tent. anyway i'm having trouble learning the sealing part of it.
after searching and reading all sorts of articles i am still a bit confused as i prefer hands on learning so here i am finally asking for help so i can get this right the first time.
so i built a simply 4*8 teardrop with birch wood plywood sides, pine bcx plywood for the roof.
the floor was sealed and covered in henrys roof tar undercoat and rubber auto undercoat.
now for the sides and roof i want to seal the wood as best i can then use a exterior paint like behr marquee to paint it red and black to match my truck and jeep.
my plan is to get a gallon of minwax polyurethane semi gloss oil based 1 gallon and mix it with mineral spirits. i was going to do 50/50 mix and apply 2 to 3 coats.
in between coats i was going to lightly sand with 220 sandpaper to scuff a little.
after that i was going to use a 100 percent coat of minwax. let dry for a few days then paint over it with the behr marquee paint and primer in 1.
i get most my supplies from home depot or menards.
if this is wrong please direct me in a better way. if there is something better to use please provide a link or pictures so i can see it.
thanks for any and all help.
so far i have loved every moment of this project.
if you need more info on my project let me know and i'll get the details as fast as i can
p.s this trailer will be stored outside during the summer and inside during the winter.
