Page 1 of 2
Building Drawers
PostPosted: Wed Jul 08, 2020 9:16 am
by tony.latham
If you've never built drawers, the thought is probably intimidating.
I build mine out of 1/2" Baltic birch and 1/4" plywood for the bases. I use Rockler Clamp It Clips (4 for $10) to hold them in place during assembly.
Here's Jay Bates explaining the method:
Easy-peasy. :thumbsup:
Re: Building Drawers
PostPosted: Wed Jul 08, 2020 10:14 am
by Ottsville
Nice, Tony. Building drawers can be intimidating but it's really not that hard to build a nice drawer that is strong and will last.
PostPosted: Wed Jul 08, 2020 5:19 pm
by bdosborn
I used a Harbor Freight Tools Dovetail jig to make mine. It takes a bit of fiddling to get the jig setup but then you can rock:
It's cuts a half blind dovetail so you definitely need a drawer front:
I think they came out pretty nice:
PostPosted: Wed Jul 08, 2020 6:47 pm
by lfhoward
Wow those dovetails are great! Beautiful drawers!
I used a Kreg pocket hole jig like the original post to make just about everything on my trailer and a tool drawer for my Jeep. It'a an amazing DIY tool.
PostPosted: Wed Jul 08, 2020 8:06 pm
by bdosborn
I think the drawers were the only thing I didn't use pocket screws on. :lol:
PostPosted: Thu Jul 09, 2020 7:46 am
by noseoil
I just use a simple rabbet joint for drawers & a dado slotted in for the bottoms. It's usually a 1/4" X 1/2" cut for the 1/2" Baltic birch plywood I use & 1/8" bottoms for the small drawers in our teardrop. Just some 1" pins from the pin-tacker & glue will hold it forever once the glue sets. On larger drawers, I would use 1/4" bottoms, but the galley drawers are only about 10" deep (front to back) so there really isn't much weight in them.
When I started as a cabinetmaker, the guy who trained me (RIP Bill Altenhoff) only used D-select white pine for drawer sides. We bought it at a local lumber yard (RIP Grant Road Lumber Company in Tucson) as 1X12 X 3/4" stock, then we planed it down to 1/2" to build the drawers. Nothing like sweet clear pine for a drawer, they were simple, clean & elegant.
Here's a drawer in the galley, without the drawer head in place yet.
160234
If you're using side mounted drawer guides which require 1/2" of clearance per side, remember to leave about 1 1/16" of clearance between the sides of the cabinet & the drawer body (that's really only 1/32" per side). That 1/16" doesn't seem like much, but leaving just a 1" difference for a 1" drawer slide set is a tight fit. Leave the 1/16" of extra "slop" & the drawer will track correctly, not bind & work as it was designed, smoothly & effortlessly!
P.S. I don't own a pocket screw jig, never found a use for it...
PostPosted: Thu Jul 09, 2020 9:31 am
by Tom&Shelly
Since Shelly and I are in the thinking/planning stage for our galley build, just wanted to say thank you for the ideas! We are really appreciating this thread.
PostPosted: Thu Jul 09, 2020 9:58 am
by bdosborn
noseoil wrote:If you're using side mounted drawer guides which require 1/2" of clearance per side, remember to leave about 1 1/16" of clearance between the sides of the cabinet & the drawer body (that's really only 1/32" per side). That 1/16" doesn't seem like much, but leaving just a 1" difference for a 1" drawer slide set is a tight fit. Leave the 1/16" of extra "slop" & the drawer will track correctly, not bind & work as it was designed, smoothly & effortlessly!
Good tip, getting the drawer slides to work smoothly was the hardest part of making drawers for me.
PostPosted: Thu Jul 09, 2020 8:59 pm
by twisted lines
Tony needs to look into cnc router's :lol:
PostPosted: Fri Jul 10, 2020 7:37 am
by aggie79
I used perhaps the easiest method of drawer construction. I purchased RTA, dove-tail, Baltic birch, drawer boxes and glued and assembled them at home. :? :D
PostPosted: Fri Jul 10, 2020 11:28 am
by Tom&Shelly
aggie79 wrote:I used perhaps the easiest method of drawer construction. I purchased RTA, dove-tail, Baltic birch, drawer boxes and glued and assembled them at home. :? :D
CHEATER!!!! :shocked:
Actually, that's an idea I hadn't thought of. Thank you! :thumbsup:
PostPosted: Sat Jul 11, 2020 8:29 am
by tony.latham
...remember to leave about 1 1/16" of clearance between the sides of the cabinet & the drawer body (that's really only 1/32" per side).
Tim: Great tip! :thumbsup:
PostPosted: Sat Jul 11, 2020 8:31 am
by tony.latham
I purchased RTA, dove-tail, Baltic birch, drawer boxes...
Aggie: Where the heck do you find those? :frightened:
PostPosted: Sat Jul 11, 2020 8:48 am
by Tom&Shelly
Not quite the same company (I think), but:
https://cabinetdoor.store/drawer-boxes/?gclid=EAIaIQobChMI9u7n3rXF6gIVMBitBh1MOgwpEAQYASABEgJO4_D_BwE
I Googled on Aggie's phrase "RTA, dove-tail, Baltic birch, drawer boxes" ;)
Thanks again, Aggie. We may only need one drawer of that type, for our galley, and the price ain't bad!
PostPosted: Sat Jul 11, 2020 9:34 am
by tony.latham
Interesting, but I just through in a 10" wide, 22" deep and 10" drawer and it was $48 unassembled. Ouch.
