noseoil wrote:Make a "sacrificial" block with a pin sticking out of it. Use your "best guess" where it will actually end up inside the trunk. You can use elongated holes to get the exact position for trial & error & a good catch. Once you have this, make a block with smaller holes that is a good fit. Use the pilot hole for the pin to have the exact location marked on the inside.
You could also use 1/8" aluminum or steel to have a shallow plate (not wood necessarily) on the inside which is the permanent location & takes up less room on the inside.
philpom wrote:Try using velcro so you can adjust the position over and over until you get it correct. Then mark the location and permanently attach it.
Users browsing this forum: Bing [Bot] and 8 guests
