V NOSE UNCONVENTIONAL APPROACH
Hello, new V Nose here, hopefully I can get some advice from experienced travelers.
I've been looking at utility conversions and here's the deal;
I have a 6X14 V nose single axel, ramp and RV doors. I got this trailer initially to haul my 1800 Trike and it came with strips on the walls that different attachment hook into, these are used to secure a load and there are a 3 baskets that are attached to the wall with slide in fasteners. It's easy to remove the baskets.
I want to convert it so that I can camp in it as well as haul my trike. Interior room is not a concern so long as my 52" wide trike will fit.
The interior plywood walls are in like new condition and I really don't want to tear the plywood out to insulate. 1. I'm an old phart and I'm lazy. 2. I'm not concerned with the additional space taken and 3. I want to leave those strips on the walls for securing a load.
Homes are built with plywood sheathing under the exterior siding, then insulated then with sheetrock, what I'd rather do is put foam insulation over the plywood, then cover that with beadboard on the lower section of the wall and use a PVC coated canvas to cover the upper walls and ceiling.
The canvas is from a large Army tent, in new condition. I can basically upholster the walls leaving the loading strips and still put my baskets up.
I can cover the RV door with insulation and upholster it, same with the ramp door but I may just put plywood over the insulation to drive up on.
I haven't seen anyone insulate over the plywood and then recover the insulation. There will be more weight with my method but nothing that significant.
From there I'll put a small galley up front, two wall beds or just two cots. I'll use a fridge and a solar generator for power with about 600 watts on the roof. Heat will be propane and I'll have a 5000 btu AC unit. I will also be installing two small RV windows.
Hopefully, you all can advise, what issue do you think there would be????
