Onebad06vtx wrote:Instead of glue and canvas,with using penetrating fiberglass resin and canvas work?
Then several coats of paint.
I figured that apply a coat of penetrating resin to the wood then lay the canvas before the resing sets up.
Then apply several more coats of resin.
IMHO you'd be better off just doing PMF as designed
...and find doing either well ends up costing very close to the same.
So I could probably easily PMF a trailer for about $440.
I'm at 33 south, so far closer to the equator than you.
