Insulating a teardrop
Postby Northernfishingnut » Wed Feb 15, 2023 4:47 pm
Has anyone tried to use spray foam as insulation in their teardrop. I would be interested in hearing the pro and cons of using it.
Northernfishingnut
Re: Insulating a teardrop
Postby tony.latham » Wed Feb 15, 2023 5:06 pm
Northernfishingnut wrote:Has anyone tried to use spray foam as insulation in their teardrop. I would be interested in hearing the pro and cons of using it.
I think it'd be a mistake. A giant mess.
Foam board works well and is easy to install. No muss no fuss.
Postby MickinOz » Wed Feb 15, 2023 7:54 pm
I think it would cause bulges in your walls.
MickinOz
Postby Shadow Catcher » Thu Feb 16, 2023 8:57 pm
We have 1.5" EPS, one reason to not use sprayed foam it is harder to remove if you have a problem
157757
Postby Pmullen503 » Thu Feb 16, 2023 11:13 pm
You won't regret insulation but you rapidly reach a point of diminishing returns. The small volume inside means you'll need fresh air. Pretty soon the air change requirements negate most of the advantage of extra insulation.
Pmullen503
Images: 67
