tony.latham wrote:Go stand by your kitchen countertop. You'll find yourself about 5" from the edge.
It's not about how far away from the edge I stand, but about what the counter top covers and how long a drawer slide I can use for the cooler. I'd like to use 28" slides for the cooler if I can. With a smaller gusset I think I can make it fit and have the front of the cooler under the counter top.
tony.latham wrote:I think you'd regret that. It would take a lot of epoxy, glass, and labor to make it work.
I would not attempt it the way shown in the picture. I think it might be feasible to cut cross sections out of 2" foam with the CNC and glue them together with wooden spars top and bottom. Would probably still involve a lot of work fairing, but I think it might be doable. Might save a good bit of weight, too.
tony.latham wrote:You may make it work with a narrower gusset. I can say that if you use 1/8" Baltic and apply it with the grain and with my suggested gusset, your hatch will work fine.
As I understand, the original implementation of this hatch style was a lot beefier than what's described in your book. I'll try to take it a small step further and report back if it worked or not. The poplar plywood I have in mind is much weaker than Baltic birch and should not cause spring back. The only problem is that right now, I cannot get any 1/8" plywood aside from 2.7mm luan. I checked a couple of weeks ago and there was lots of stock (150+ sheets), today there's nothing. I don't plan to start before the Christmas holiday anyway, so I hope the situation improves before then.
