Galley walls and hatch
I am wondering if there are some weight savings to be had by modifying the galley walls and hatch from what is described in Tony Latham's book. The sketch below shows a cross section of the galley wall and hatch as described in the book on the left. The construction process is to skin the wall of the galley on the inside and out just like the rest of the wall and then cut off the hatch side pieces. Then, an 1/8" spacer is glued to the inside of the wall, followed by the 1/4" galley wall that protrudes and seals against a gasket in a recess in the hatch.
On the right of the drawing is a design that removes 1/4" of plywood from the thickness of the galley wall. I would construct this by omitting the interior wall skin aft of the bulkhead and instead attach the 1/4" galley wall directly to the 3/4" skeleton. In Tony's design, there are about 7 square feet of galley wall area on each side. The modification would save approximately 12 pounds if Baltic birch is used for the plywood.
Is there any reason why the modified design might cause problems?
