X Hinge thingies...
X Hinge thingies...
Postby Shrug53 » Sun Aug 29, 2004 11:15 pm
What are those X type hinge things on the sides of pop-up/pop-top campers. You know like the kind used on the original Compact that Andrew modeled his after?
"Better living through reckless experimentation"
http://www.forgottenclassics.com
Shrug53
Postby Shrug53 » Sun Aug 29, 2004 11:33 pm
If anyone knows what I am talking about and where I can buy them, please let me know.
Shrug53
Postby angib » Mon Aug 30, 2004 4:53 am
I reckon these were probably custom made for the Compact.
One thing to notice is that (I think) later Compacts had the scissor lift on the inside of the canvas. This seems like a good idea as then you can adjust it, lubricate it, play with it, etc, easily. However it does mean that you can't simply pull the 'canvas' in as you let the roof down.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Nick Taylor » Tue Aug 31, 2004 12:39 pm
There was one at the Spamboree that had the mechanism on the inside. Not a scissor lift though. You can kind of see them in the picture below.
A potential problem I saw with this was that you could accidentally get grease on yourself or the inside of the canvas.
Click on the pictures for larger views.
Nick.
Nick Taylor
Postby angib » Tue Aug 31, 2004 12:58 pm
I'm pretty sure Nick's pictures show a later Compact roof, which has independent front and back lifting, not a parallel lift. I think the instructions (search the FiberglassRV forum for these) were fairly adamant that you had to raise the back of the roof first and then the front, and the reverse when lowering.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby AmyH » Fri Sep 24, 2004 1:03 pm
They are sometimes referred to as "canopy lifters", and you can find them through the following sites:
http://www.caravansplus.com.au/index.php?cPath=70
http://www.camec.com.au/53-Hardware%20Pop%20Tops.htm
Not real cheap, but I started looking into them when I saw Andrew's version of the Compact.
Amy :)
Amy
"...follow humbly whereever and to whatever abyss Nature leads, or else you shall learn nothing." T.H. Huxley
Photo Log
Camping Trips with the Tear
AmyH
*The 300 Club
Users browsing this forum: Bing [Bot] and 7 guests
