Attach aluminum to the hatch?
Postby rmcelroy » Tue May 02, 2006 9:19 am
After building the framing for the hatch over the weekend, the question of how to attach aluminum to it has been bothering me. I have solid 3/4x2 pine ribs and 3/8 bendable luan material to work with. The outermost ribs are a little over a half inch from the edges of the luan-I have a couple of different options I think, but suggestions would very much be appreciated.
Regie
Wheather you think you can or you think you can't, your right.
Henry Ford
rmcelroy
Images: 27
Postby madjack » Tue May 02, 2006 11:15 am
Regie, our hatch was similar in that we used a 3/8th bendable ply on it...we used RV insert edge molding on top and plain angle underneath to make a sandwich and used rivets from the bottom up, covering the "stud" with the insert in the top molding...I'm sorry that I really don't have any pics of this process as we were up to our ears (literally) in urethane windshield sealant and couldn't grab a camera...
Postby rmcelroy » Wed May 03, 2006 12:34 pm
Thanks Madjack, that sounds perfect. I have really been undecided about the finish method, one day I'm pro AL and then the next I'm back to paint. I'm now pretty sure its AL, at least until tomorrow :lol:
Regie
Henry Ford
rmcelroy
Images: 27
Postby rmcelroy » Sun May 07, 2006 2:28 pm
I just found these fasteners, and was thinking about using them instead of real rivets. Just cause I never have used rivets before---any thoughts
http://www.screwpost.com/product_info.p ... ducts_id=3
Regie
Henry Ford
rmcelroy
Images: 27
Postby madjack » Sun May 07, 2006 2:51 pm
Regie, they would probably work...at least you wouldn't have the rivet "stud" to deal with...keep in mind what you have shown is designed to bind documents into a folder and MAY or MAYNOT be able to be tightened sufficiently for your application...I would use some kind locktite on the threads and seal the opening they pass thru very well...
Postby rmcelroy » Mon May 08, 2006 9:18 am
Well horse feathers!!!! Your right-even looking at the steel ones by the time I get one that is long enough the diameter is way to big. I'll have to bite the bullet and learn to rivet. That is one of those skills you need to have when you start but don't have until after you finish :)
Thanks Madjack
Henry Ford
rmcelroy
Images: 27
Postby halfdome, Danny » Mon May 08, 2006 11:48 am
rmcelroy wrote:I just found these fasteners, and was thinking about using them instead of real rivets. Just cause I never have used rivets before---any thoughts
Regie
I used those on my hatch and found that I needed two sizes to make it work but I'm quite satisfied :thumbsup: . They won't take too much of a torque since they are aluminum. They are designed for binding pages together. 8) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Sonetpro » Mon May 08, 2006 4:03 pm
I did as MJ did but left them exposed. I used Stainless steel rivets. It's pretty easy. The stud is under the weather stripping.
Sonetpro
Images: 107
Postby halfdome, Danny » Mon May 08, 2006 7:54 pm
Sonetpro wrote:I did as MJ did but left them exposed. I used Stainless steel rivets. It's pretty easy. The stud is under the weather stripping.
How did you pein them? My super duper hardware store (Mc Lendens) sells them but has no idea how to apply them. Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Sonetpro » Mon May 08, 2006 9:05 pm
I didn't pien them. I used pop rivets. You just drill a 1/8" hole put a dab of sealer then insert a rivet in the gun and tighten till they snap. Then put a dab of sealer in the hole.
Pop Rivet
Sonetpro
Images: 107
