Technical Problem on Frame
Postby Classic Finn » Sun May 14, 2006 7:49 am
Dear friends.. Im outside doing some work on the teardrop... even on mothers day...wife is assisting or should I say supervising.. :D
I have a slight problem... maybe you can assist .... My frame has the leaf
springs and the brackets are unfortunatley welded on one side of the frame (outside) I wanted to have the walls come down to the lower frame
edge... in order for me to do so I have to build the floor so that it comes out from the frame almost 1 inch in order for me to clear the leaf spring bracket and bolt head....will this much be ok for the floor to stick out? And on both sides? Otherwise it will look terrible..The walls are 3/4 inch ply..
I can take a photo of it if I didnt explain it fully... If I build the wall on the frame itself the bracket on one side and the bolt will show.. and it will
also look bad in my opinion...
HELP... :cry:
Classic Finn
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Nitetimes » Sun May 14, 2006 8:03 am
I think I understand what you are saying and I can't see where it will be a problem except.... I would turn the bolt around so the nut is on the outside, maybe drill a slight recess for it to hide in just leaving room to get a wrench in, otherwise you willl never be able to get the bolt out without making a hole in your side. One other thing, you are adding nearly 2" outside your frame, will you still have the clearance for your tires?
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Classic Finn » Sun May 14, 2006 8:17 am
Nitetimes Here is a photo of it...
It will still have the bracket on there sticking out but I,ll take and change the bolt head towards the inside ... it will help some and then I wont have to have the floor stick out so much.. Maybe 1/2 inch instead...But then the nut will be there just the same... :shock: 2 inches will be tight for the tires... Maybe :QM
Classic Finn
Classic Finn
Images: 146
Postby Chip » Sun May 14, 2006 8:27 am
Finn,,, bring the body sides out to just clear the spring hangers and down to cover the frame,,, Then take a peek at the springs with the tires and fenders in place,,, ya probably will not even be able to see the hanger bolts etc when all pieces are in place,,,
chipper :thumbsup:
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby Classic Finn » Sun May 14, 2006 8:29 am
Thanks Chip I,ll give it a shot... (A shot of Pickle Juice) ahh not Yet.. :lol: Or then again..maybe that too... :picklejuice:
Ok I know the fenders wont sit that low but I thought Id throw it in there just for a (Look See) :twisted: :hammer:
Classic Finn ;)
Classic Finn
Images: 146
Postby madjack » Sun May 14, 2006 10:16 am
Heikki, I'm with Chipper on this one, bring the sides out and down just enough to clear the hanger...you will wanna seal between the frame and sides, so I would cut a piece of lumber to fit in that area...seal it and the inside of your sides very sell and caulk it all in with a good grade of sealant...something like 3M 5200 or SikaFlex 221, 252, 552...or what ever kinda reindeer s**t you can come up with :lol: ;)
Postby Classic Finn » Sun May 14, 2006 10:21 am
madjack wrote:Heikki, I'm with Chipper on this one, bring the sides out and down just enough to clear the hanger...you will wanna seal between the frame and sides, so I would cut a piece of lumber to fit in that area...seal it and the inside of your sides very sell and caulk it all in with a good grade of sealant...something like 3M 5200 or SikaFlex 221, 252, 552...or what ever kinda reindeer s**t you can come up with :lol: ;)
Dear Madjack
We have both products you mention... I,ll pick up some of that stuff tomorrow.... :thumbsup:
Thank you gentleman for the advice - Whew! I was goin for the pickle juice there for a stress reliever... :lol: :lol: :lol:
I,ll get more pics up for you shortly as to what I did... :hammer: :coffee:
Classic Finn
Classic Finn
Images: 146
Postby madjack » Sun May 14, 2006 10:33 am
Heikki, in further thinking about it, you want to be careful not to create a space that water can get into and just sit...you might want to leave that space open so water will drain out or seal the floor to the frame along with that gap
Postby rainjer » Sun May 14, 2006 10:41 am
What about just using a router & hog out an area on the inside of the side wall to slide over the hanger?
rainjer
King Koleman
Images: 11
Postby Classic Finn » Sun May 14, 2006 11:15 am
rainjer wrote:What about just using a router & hog out an area on the inside of the side wall to slide over the hanger?
That Could be an idea...
Madjack, Chip and Nitetimes.. I went out to measure it again and I would have to bring the floor out 3/4 of an inch on each side (from outer edge of
frame) in order to clear the bolt heads on the brackets - then install the walls hanging on sides..PS it does also have a washer under the bolt heads..
Or I could bring the floor out and still build on top of the frame instead not lowering the sides however the ugliness of them brackets then still will fully be shown.. :roll:
Gee Im hoping that I explain myself well enough...
Classic Finn
Classic Finn
Images: 146
Postby rainjer » Sun May 14, 2006 11:20 am
I would drill a hole where the bolt is to be able to service the springs.
rainjer
King Koleman
Images: 11
Postby Classic Finn » Sun May 14, 2006 11:25 am
rainjer wrote:I would drill a hole where the bolt is to be able to service the springs.
I,ll go and mount them wheels on shortly too then we can see what were up against if anything... :?
We could possibly router an area out in that area on the 3/4 Plywood..
Madjacks and Chips idea is also a plan to follow...we,ll see with the wheels on...
Classic Finn
Classic Finn
Images: 146
Postby rainjer » Sun May 14, 2006 11:33 am
I wanted to have the walls come down to the lower frame edge..
As I re-read your original post I may have missed something.
Are the bolt an issue?
The bolts are already below the bottom of the frame.... :thinking:
rainjer
King Koleman
Images: 11
Postby Classic Finn » Sun May 14, 2006 11:42 am
Geeee now that I looked again :lol: :lol: I guess the wall will not come down that far indeed...
Its the ugly bracket that is welded to the side of frame that is though..
That bracket is about 1/4 inch thick....
Remember Im just learnin this inch system... :lol: :lol: but ok no the wall doesnt have to come down that far...
But its sure UGLYYYYYY! :D Let me go and measure the length of the bracket...
Classic Finn
Classic Finn
Images: 146
Postby Kurt (Indiana) » Sun May 14, 2006 11:53 am
Classic Finn ;)
Heikki, If you make the side come down to the bottom of the fender position, the "low" look would be pretty cool.. It almost looks as if the fenders will cover the spring shakles. I had a similar problem with mine. I wanted a "lowered" look so I added the lower skirt to complete the shape and get a lowered look.
Image My frame line is at the top of the trim piece is on the side,
Keep us updated.
CRA2023 Web Site
"Wall of Fame 2011-2021"
Kurt (Indiana)
Images: 178
