Adding trailer brakes
Postby josephhanson » Mon May 15, 2006 11:12 am
I've been reading past posts about trailer brakes, and have decided to add brakes to my trailer. Can anybody tell me, will adding brakes make my wheels extend farther out? Also, I would like to install electric brakes, is there a good place to look for detailed instructions. I have no idea what is needed for the trailer or for the car.
Thanks in advance,
Joe Hanson
Joe
josephhanson
Images: 46
Postby pgwilli » Mon May 15, 2006 1:48 pm
The Dexter Axle web page has a lot of information in their Trailer Resource Library section.
http://www.dexteraxle.com/torflex_axles
Paul, Norma & the Girls
2014 Escape 21
2006 Chevy Trailblazer
pgwilli
Images: 75
Postby Nitetimes » Mon May 15, 2006 3:44 pm
Shouldn't change anything at all. You just remove the idler hubs, install the backing plates and brakes then put the drum on. It takes the place of the idler hub, you should still have the same hub face measurement when you are done.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby IndyTom » Mon May 15, 2006 9:18 pm
Joe, Like Paul said, check out Dexteraxle.com any of the utility trailer parts sites. If you want to see the parts up close, come up to Carmel and visit Northside Trailer. They have all the parts in stock. Im not sure I would buy from them (the are pricey) but you could at least see what you are getting into. And if the timing is right, you could help me put the sides on the Hoosier MegaTear. :lol:
Seriously, its not a big deal, just kinda expensive.
Never trust a skinny cook
IndyTom
Images: 42
Postby Micro469 » Mon May 15, 2006 9:28 pm
Hey guys, maybe he should first check to see if he has the square plate on his axle to bolt the backing plate to first. If the axle wasn't made for brakes, he'll have to get them welded on first, so it might not be a simple retofit......
:roll:
John
Micro469
Images: 382
Postby josephhanson » Tue May 16, 2006 7:50 am
John, I checked, I don't have the square backing plate. I'll check and see if there is a bolt on plate.
Joe
josephhanson
Images: 46
Postby IndyTom » Tue May 16, 2006 8:30 am
Joe, that plate has to be welded on. It is what takes all the stress when the trailer brakes are applied. I have heard that it takes a very competent welder to weld those on because of the load they carry. Once you get those on, everything else we have said applies. :lol:
IndyTom
Images: 42
