Fender Mounts & Door #2
Postby rainjer » Sun May 21, 2006 1:48 pm
I decides to tackle the fender mounts today. Here is what I came up with.
Two pieces of 1/2" MDO, som bolts, some screws & some t-nuts.
I will glue & screw the MOD pieces to the wall. & then Bondo the top.
I wil the run a bead of caulk between the fender & the mount to keep it from holding water.
I used t-nut & bolts to attach the fender to the mount. Every thing under will get a coat of rubberized automotive undercoating.
This is not 100% complete but I had to share what it will look like.
rainjer
King Koleman
Images: 11
Postby madjack » Sun May 21, 2006 4:11 pm
...that looks good BUT, me personally, I would consider soaking that wood piece down with some epoxy...especially the edges before the doing the undercoating.....
Postby rainjer » Sun May 21, 2006 6:45 pm
Finished door #2. Man it was so much easier the the first one.
I just need to add the trim & hardware.
:applause:
rainjer
King Koleman
Images: 11
Users browsing this forum: Google [Bot] and 3 guests
