Sealing 1/8" plywood with diluted Tite-bond II?
My camper is almost completely skinned (front/top/back). I used the same paneling material that I used for the headliner. At least the cheap paper pattern was the same. It is fairly nice 3-ply that isn't junk in the middle like lauan. I scored the pattern with 60 grit and sprayed it with water. In about 1/2 hour it pealed right off.
I was going to seal the top with polyurethane, but I got to thinking about how I sealed some of the edges of the lauan that I used for the door with diluted Tight-bond II. It dried hard and sanded nicely. What if I painted the entire roof of cheap plywood with that. Maybe it would strengthen the wood some and that stuff is waterproof. Maybe polyurethane would strengthen the wood. Whatya think?
A. Crazy idea
B. Hey, maybe he has something there
C. Polyurethane will be good enough
D. What does he think, he's building a birdhouse here?
E. Doesn't matter, cheap is as cheap does
Comments?
Ed
A. Crazy idea
Comments?
Ed
