sealing the door
sealing the door
Postby 240zron » Tue May 30, 2006 1:09 am
Hi,
I'm getting ready to start working on installing the door. I'm looking for suggestions on what to use, And how to go about it (pics would be great)
I did a search, But didn' really find anything.
I'd ilke to do this as easy as possible, But don't want it to leak. I have pics of the door opening in my album
Thanks,
Take care,
Ron Potts
Member team Genesis USA
240zron
Images: 22
Postby asianflava » Tue May 30, 2006 2:27 am
This is how I did mine, I think the trim pieces helped a lot. It allowed the water to run along it rather than right into the door. I had just the inside seal on it at Cedar Hill and it leaked. I put the aluminum and trim pieces on without the primary seal and there was no leaks. I put the primary seal on there as extra insurance.
Oh yeah, I have the offset hinges that Grant sells.
asianflava
Re: sealing the door
Postby Joanne » Tue May 30, 2006 3:00 pm
I was working on my door seals this past weekend. Here's a couple of pictures from my website.
This shows how it will be installed.
This is the door jamb as it is completed.
The rubber seal came from Grant at Lil Bear....of course! :thumbsup:
Joanne
240zron wrote:Hi,
Thanks,
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby 240zron » Tue May 30, 2006 10:18 pm
Joanne,
Nice job on the trim, Not sure if it will work on my door, I have rounded corners, So not sure how good it would bend, But I may try it.
Thanks
Take care,
Ron Potts
240zron
Images: 22
Postby bennelson » Wed Jun 07, 2006 4:55 pm
I am builing using the Cubby plans.
Right now, I just put on the first door. The plans call for using 1/4in rubber tube gasket on the T-Molding on the door.
When I do that, the door won't close!!!
This must be what all that talk about "offset hinges" is about.
If I space out the body side of the hinge, won't that do the same thing?
Also, how the heck do you attach rubber tube weather stripping to aluminum trim!?!? Nothing seems to stick to it, and I haven't seen any self-sticky tubing!
Any input is appreciatted!
-Ben
still no idea what i'm doing...
bennelson
Images: 53
Postby Endo » Wed Jun 07, 2006 7:12 pm
bennelson wrote:If I space out the body side of the hinge, won't that do the same thing?
-Ben
I spaced out the hinge side, it worked well.
I used self stick X-treme rubber weather seal made by Frost King. It is available at just about any hardware store. It sticks to the t-molding just fine.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby kayakrguy » Tue Aug 08, 2006 11:24 am
joanne,
How did you get your seal to stick to theangle?
What hinges did you use?
And, wow, that finish on the door jamb is shiny--looks like plastic! Is that paint?
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
Postby bledsoe3 » Tue Aug 08, 2006 11:43 am
Here's a picture of my door jamb.
I used the torpedo hinge from Austin Hardware and spaced the door out 1/4". Then wraped in T-molding from Grant and his self stick seal.
bledsoe3
Images: 112
Postby rampage » Tue Aug 08, 2006 12:59 pm
When you say, "spaced out the door 1/4", are you saying that you put a 1/4" shim under the hinge?
"If you can't be a good example, then you'll just have to be a horrible warning"
rampage
Images: 5
Postby sid » Tue Aug 08, 2006 2:08 pm
rampage wrote:When you say, "spaced out the door 1/4", are you saying that you put a 1/4" shim under the hinge?
We had to space ours out 1/8 inch. And yes, that's under the hinge on the trailer side, not the door sid.....
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
sid
Images: 194
Postby bledsoe3 » Tue Aug 08, 2006 11:22 pm
Yes.
I still need to finish it off (make it look purty).
bledsoe3
Images: 112
