Page 1 of 2
Mahogany Question
PostPosted: Fri Jun 16, 2006 5:24 am
by Classic Finn
Does anyone here have mahogony on or in their teardrop? If so would anyone have any photos of what it may or will look like with a nice Clear Marine Varnish or Laquer?
Best wishes to All
From the Land of the Midnight Sun
Classic Finn
PostPosted: Fri Jun 16, 2006 5:28 am
by bledsoe3
Finn, I think Doug may have some on one of his. Look in his gallery.
PostPosted: Fri Jun 16, 2006 6:31 am
by 48Rob
This picture shows Mahogany trim on Birch.
It is very dark...
Rob
PostPosted: Fri Jun 16, 2006 7:27 am
by Classic Finn
Thanks bledsoe3 and 48 rob..
I,ll check it out... Wow that Mahogony does look good with a clear finish..
Classic Finn ;)
PostPosted: Fri Jun 16, 2006 7:44 am
by mbader
Here is Joubert Okoume (African mahogany) with oak trim.
More at: http://roadkillcafe.us
PostPosted: Fri Jun 16, 2006 7:58 am
by Classic Finn
WOW and Ahhh
Now that does look Beeeeutiful... How many coats of clear was applied in order to achieve the nice gloss or shine?
PS What brand of lights are those you have? Model Number? Did they come from RW JOHNSON?
:thumbsup: :thumbsup:
Classic Finn
PostPosted: Sat Jun 17, 2006 8:09 am
by mbader
Thanks.
The finish is Bristol marine varnish. http://www.bristolfinish.com/
This is the greatest stuff. It's a 2 part system so it drys fast. You can recost in 1-2 hours.
I put on 5 coats without sanding between coats.
Sanded and then put on the 6th coat and your done.
The taillights are 32 Ford reporduction.
http://www.tperformance.com/street_rod_ ... aillights/
http://www.tperformance.com/street_rod_ ... _brackets/
Malcolm
PostPosted: Sat Jun 17, 2006 8:46 am
by Chris C
Glad to see someone else using Bristol Finish. :applause: Looks great! :thumbsup:
PostPosted: Sat Jun 17, 2006 10:10 am
by doug hodder
I used marine grade okume, with dark colonial red mohogany aniline dye, epoxy and auto clear coat...maple trim with light yellow aniline dye...Doug
PostPosted: Sat Jun 17, 2006 11:44 am
by Classic Finn
Nice info...has anyone used the mahogony to do the interior? :thumbsup:
Classic Finn
PostPosted: Sat Jun 17, 2006 11:46 am
by Classic Finn
I couldnt help but observe the lighting Doug has.... :lol:
Doug these lights I have are actually for my 46 Chev truck..i think maybe same as yours. :thinking:
Are them 42 - 46 Chevrolet lights you have?
Whats the best way of testing them right out of the box? I was trying to see the brackets as I dont have them or how they are installed...Are they LED? Or how does one change them to LED?
Classic Finn
PostPosted: Sat Jun 17, 2006 9:31 pm
by doug hodder
Heikki...that's what I have, 40-54 GM truck lights...only this time around I did the stainless bodies for them...did you get those from TaillightKing.com...if so...he has the LED boards available for them...I'm willing to bet yours are incandescent as you have glass lenses in the original dark color...the LED ones are plastic and more clear...check my album, I've posted some pics with them lit up...and to test yours...they ground through the stud on the back of the light...just expose the wires, and touch them to the + on the battery and ground the stud on the -....2 wires...1 for brake, 1 for running..the LED.s have 3 wires on them, brake running and ground..and I'll shoot a pic of a bracket to show you...it's not a real official one...I made them myself...Doug
PostPosted: Sat Jun 17, 2006 11:47 pm
by apbos
Finn
Since I know your also a car nut :thumbsup: take a look at the dash of my Triumph Roadster http://pg.photos.yahoo.com/ph/paulbos@s ... /my_photos . Seven coats of (Deft) laquer, 1500 grit wet sanded between each coat. Came out better than I could have dreamed. If you need some veneer tips let me know.
Paul
Six months into a Two Year Project Tow vehicle and trailer
PostPosted: Wed Jun 21, 2006 6:05 am
by Classic Finn
Hey There
I finally got a photo of the Interior Mahogany ... Has anyone heard of Sable mahogany? This is whats being used for our interior..Took a couple photos as best we could to bring out the color... :pictures: It kind of changes in color depending on the angle of looking at it.. ;)
Here is a sample of the veneer ... Hope you folks like it as much as we do.
It will be varnished or as recommended here by wood craftsmen to lightly oil it then it will bring out the nice grain...The cost is outrageous here too..but quality is what we want so..... :fan:
Classic Finn :thumbsup:
Looks like Sapelle
PostPosted: Wed Jun 21, 2006 2:23 pm
by Guy
Dear Heikki,
The sable mahogany looks like Sapele Mahogany used for marine plywood.
