Gloss or not to gloss, that's the question!
Postby sunny16 » Mon Jun 19, 2006 8:10 am
I painted my trailer with oil base primer over the weekend. Looks great so far.
My question to you on the forum is, if you painted your tear, did you use gloss paint , semi-gloss or other? What problems, concerns, good stuff did you find with what you used? I hope to get er painted by the weekend. Camping is coming up real fast! :thumbsup:
Sunny16
I cut it three times and it's still too short!!
Perfection is all I ask.......
sunny16
Images: 70
Postby Ira » Mon Jun 19, 2006 8:25 am
Sunny, I think it depends on the brand AND the color. Some glosses are REALLY glossy, while most semi-glosses give you a great gloss anyway.
But I would think you would definitely want a gloss for cleaning.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby surveytech » Mon Jun 19, 2006 1:01 pm
I used two coats of oil gloss on mine.
Applied it with a foam roller. It took forever to really dry. It was dry to the touch in about a day but I dont think it reached full hardness until about a week. (weather was sunny and 80 when I painted it). I painted outdoors and it did collect some bugs in the paint. I waited till it was dry then pulled them out of the paint.
I used gloss to make it easier to wash and clean up. So far so good.
Last camping trip the people next to us at the campground were surprised to hear that it was painted plywood and not FRP.
I kept the trailer in the garage and I bet it was a week or more before it didnt smell like paint out there.
Be careful of the roller choice. Some will fall apart and leave "fuzz" all over (and in) your pretty new paint job.
Good luck!
Walter
surveytech
Images: 6
Postby rainjer » Mon Jun 19, 2006 2:09 pm
It depends on the finish you are looking for.
Remember the higher the shine, the more prep you need to do because it will show more inperfections. My walls are MDO so the are really smooth. My roof & hatch are laun, they looked & felt smooth after I sanded them until I painted them. Now it looks like I troweled the paint on because of the grain.
I have decided on the 10 ft rule: How does it look from 10 feet away.
I know I would never get a perfect finish, I do have a paint booth & some day I plan on putting a aluminum skin on.
rainjer
King Koleman
Images: 11
Postby surveytech » Mon Jun 19, 2006 3:01 pm
rainjer wrote:It depends on the finish you are looking for.
Yeah good point!
I used a short nap roller cover with the primer and it added a very small amount of texture to the finish which helped the over all appearance.
then applied the two coats of finish.
I agree.........I knew I would never get a perfect finish. Just one good enough.
surveytech
Images: 6
Postby sunny16 » Mon Jun 19, 2006 3:43 pm
I used a 3/8" nap roller for the primer and it did give it a nice "textured" finish taht I think looks good. Some of the wood must have sucked up the paint as it is more smooth. I think if I use two coats of paint to finish it the texture will be more even and it won't show any wood grain. An I think the gloss finish will be better for cleaning any grime or dirt/dust that will get on it. I still welcome any and all comments. I know there are many others who have painted trailers. Thanks so far.
sunny16
Images: 70
Postby surveytech » Mon Jun 19, 2006 6:07 pm
Sunny,
I also sanded mine after I applied the primer.
I think it helped get the finish more even.
light sanding though.....not much.
Walter
surveytech
Images: 6
Postby doug hodder » Wed Jun 21, 2006 10:47 am
I know that with an automotive paint...gloss gives you a more durable finish...in the sign industry flattening agents are used regularly in these paints, to hide a lot of cosmetic flaws...however they do oxidize much more rapidly...I would imagine the same thing exists on any of the oil based/latex also...a gloss surface is much more resistant to any UV/dirt/oil etc....just a hunch...Doug
Postby cracker39 » Wed Jun 21, 2006 3:09 pm
I used oil gloss enamel, sprayed on. It does tend to show any imperfections. As for the plywood grain, I worked really hard to fill all the grain, but didn't do such a good job on the tongue box. You can really see it there. Use a water putty to fill in the grain, sand, and fill again (and again) if necessary to get it smooth.
I use the touch method. If you can feel any grain, you'll see it after you paint. If it feels smooth, chances are it will have a smooth painted finish. I'm in the process of sanding and repainting some areas prior to putting on edge trim that I found out that I needed after I was done. I hope to have a good, smooth surface all over when I'm finally done (well, except for that tongue box).
Dale
cracker39
Images: 233
Postby doug hodder » Wed Jun 21, 2006 8:09 pm
I'm sure that a lot of people know this trick, but for those of you that don't...prior to putting on any finish, wipe the wood with a damp rag...the moisture will raise the grain, let it dry, and you can lightly sand off the "fuzzy" areas with very fine paper...those are the little fibers that are going to raise when you put the finish to it...your last chance to get them taken care of....Doug
Postby kayakrguy » Sun Jul 02, 2006 8:41 am
One advantage of a gloss is that it is more heat reflective, everything else being equal...
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
Postby cracker39 » Sun Jul 02, 2006 10:41 am
Now that you brought heat reflectiveness... Most heat reflective roof coatings are silver in color. I found by testing, that white will reflect heat better than silver. Back in the 60s, I painted two of my children's swing seats, one silver and one white. After a couple of hours in the sun, they could sit on the white seat, but sitting on the silver seat burned their little bottoms. I think I'll test a piece of metal painted white against my chrome bumpers on the truck to see which reflects heat better.
Dale
cracker39
Images: 233
