What did you use?
What did you use?
Postby bledsoe3 » Tue Jun 20, 2006 9:34 am
For those of you that trimmed your trailer with aluminum, did you have to cut it length wise and what did you use? I've heard of using a table saw but what type of blade would I use. I've also heard of a router being used but what bit should I use?
bledsoe3
Images: 112
Postby Sonetpro » Tue Jun 20, 2006 9:43 am
I just used a power mitre box fine blade. Just cut slow and wear goggles.
I tried a metal abrasive but it melted it.
Sonetpro
Images: 107
Re: What did you use?
Postby Steve_Cox » Tue Jun 20, 2006 10:29 am
bledsoe3 wrote:For those of you that trimmed your trailer with aluminum, did you have to cut it length wise and what did you use? I've heard of using a table saw but what type of blade would I use. I've also heard of a router being used but what bit should I use?
Bledsoe,
For cutting lengthwise, I've always used a carbide blade in a table saw. The main thing is using featherboards and hold downs to keep the aluminum flat on the table. Another trick I found that helps is to keep the blade height adjusted to right at the thickness of the aluminum. It reduces chances for the blade teeth to take a big bite of aluminum. I've tried the router table but found all the waste from the cutter too extreme, too big of a mess to clean up.
Steve_Cox
Images: 196
Postby madjack » Tue Jun 20, 2006 11:36 am
...table saw, standard carbide ripping blade, 2 feather boards, full face shield...we have not had a lot of luck cuttin' with a router, no matter what speed or type of cutter( a spiral upcut seemed to work best)...
Postby rampage » Tue Jun 20, 2006 12:12 pm
Bledsoe,
I've heard reference to this "featherboard" before. Can someone explain what this is? Maybe a pic. Thanks
"If you can't be a good example, then you'll just have to be a horrible warning"
rampage
Images: 5
Postby Ken A Hood » Tue Jun 20, 2006 12:15 pm
It holds your work tight to the fence, and reduces possible kickback.
Ken A Hood
Images: 42
Postby alaska teardrop » Tue Jun 20, 2006 12:20 pm
:thinking: Vertical bandsaw with a fence. :thumbsup:
alaska teardrop
Postby madjack » Tue Jun 20, 2006 12:39 pm
Ken A Hood wrote:Image
...when cutting trim down, use a second one attached to the fence to hellp keep the piece from jumping up also...the more secure you keep the oiece the bette/smoother the cut...
Fred, we use a band saw also but it is easier for us to use the table saw in the shop because of setup and extra room to work long pieces...basically the bandsaw is in more closed quarters than the table saw(in our shop)....
Postby Ken A Hood » Tue Jun 20, 2006 1:01 pm
Agreed, I was just posting a generic pic of a featherboard in use.....it's from the GRR-Ripper site ( http://www.microjig.com ).
Ken A Hood
Images: 42
Postby asianflava » Tue Jun 20, 2006 3:36 pm
Bought a HF horizontal bandsaw. Luckily it was on sale, with the coupon it was pretty cheap. I honestly don't know where I'm gonna store it now but it saved me a lot fo time and frustration. Especially in the areas where I had to miter them.
Getting the bandsaw to work right is another story in frustration. After I figured it out, it worked like a champ.
asianflava
Postby Mike Spicer » Tue Jun 20, 2006 10:38 pm
I used a 10" miter saw with standard carbide blade for cross cuts. used a scrap piece of wood behind thin alum to back it up. Go Slow.
I used table saw for riping. Backing material to keep it from bending.
Hope this helps, Good luck
Not sure if Picks will show up . so heres a link to them
http://pg.photos.yahoo.com/ph/spicerm@p ... /my_photos
Mike
Home Built 4x10
Mike Spicer
Images: 14
Postby sunny16 » Tue Jun 20, 2006 11:27 pm
I too just used my 10" miter wood saw with the standard blade. I only cut 1/16" aluminum angle and it worked great. You just have to be careful with the flying bits of aluminum and go slow. I was amazed at the clean cuts I got. I was going to use the metal chop saw but after my first cut on the miter saw, that's all I used. The 45 degree angles came out perfect and if I needed to trim a bit more off, it was very simple to do. Just how I did it....... :thinking:
I cut it three times and it's still too short!!
Perfection is all I ask.......
sunny16
Images: 70
Postby TRAIL-OF-TEARS » Wed Jun 21, 2006 8:37 am
I cut my trim using a good ol hack saw. The aluminum cuts fairly easy.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
