Cubby Window
Cubby Window
Postby lcurrie » Tue Jun 20, 2006 6:52 pm
I've just started building my Cubby and it's time to order the windows!
I'm not sure why but this has turned out to be a very difficult decision for me and i'm looking for some guidance.
I KNOW i want some with rounded corners and have narrowed it down to the either the ones on the lil bear website OR the ones on the tjtrailers site.
It looks like the one's on the lil bear site are slightly bigger (14" x 21") - which i like. BUT the scale drawing in the back of the plans seem to match the tjtrailers site (12x18) size.
Can i get away with the bigger size? Any reason to choose one over the other?
Thanks!
Lynn
lcurrie
Postby madjack » Tue Jun 20, 2006 7:02 pm
..put as large a window as you can comfortably fit in the window...no cubbies here but we used the 15x24 from tjtrailers...we latter found out that those windows come from RedNeck Trailer SUpply and we could have gotten them 20 bucks cheaper from them...
Postby lcurrie » Tue Jun 20, 2006 7:09 pm
Great info. Thanks, MadJack.
That leads me to the next question then...
What about buying one of those bigger ones and putting it vertical instead of horizontal? Does it still open/travel/keep the rain out correctly?
Oh, and when you say "as big as you can get away with" - how big should the wood edges be around the windows to keep the doors structurally stable? It looks like the scale drawing only has about 2.5" on the left side of the window and 3" on the smallest part (because of the curve) on the right side.
Lynn
lcurrie
Postby madjack » Tue Jun 20, 2006 7:31 pm
Lynn, 2/3"s should be sufficient to keep structural integrety in the door...as to mounting vertically...SteveH and others have done exactly that...you have to drill new drain holes in the bottom of the window frame since it comes only prepared for horizontal mounting...no big deal(if you buy 'em you will see what I mean...)
Postby lcurrie » Tue Jun 20, 2006 8:51 pm
Thanks for the info!
Lynn
lcurrie
Postby oklahomajewel » Tue Jun 20, 2006 9:36 pm
Welcome Lynn!!! Can't give you advice on the windows but glad to see another Cubby in our South Central group! Keep up the good work, and show us the mon... i mean show us the pictures!!!
Where in Austin? My brother is in Leander.
Julie
oklahomajewel
Images: 82
Postby asianflava » Tue Jun 20, 2006 10:07 pm
If you want to take a trip to Rosebud-Lott there is a camper manufacturer that has windows. I got mine there, they are the same ones Grant sells. BTW Rosebud-Lott is East of Temple, I had to look it up.
asianflava
Postby TRAIL-OF-TEARS » Wed Jun 21, 2006 8:48 am
Lynn,
You could talk to Carry with Camp-Inn they have the windows you seek That is where I got mine. Paid about $40.00 each. Good luck
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
Postby lcurrie » Thu Jun 22, 2006 10:04 pm
Thanks for all the great info!
Julie - i live in Central Austin. I go out to Leander to cycle quite a bit. They've got some yummy BBQ nearby. :)
Lynn
lcurrie
