Galley sides in fabric?
Postby Ira » Mon Jun 26, 2006 7:59 am
For those that have followed my galley saga, an idea hit me yesterday:
Do you think I could I use contact cement to put fabric on the sides, and then varnish over? I'm sure there's a ton of great themed stuff out there, and the size I can get it cut to should be perfect.
Is our resident seamstress Doug in the house?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Chris C » Mon Jun 26, 2006 8:08 am
Fabric or wallpaper. Either would look good and cover any blemishes you might have. Good solution. :thumbsup: Remember, it's not a mistake if it can be corrected. :lol:
Chris :D
Chris C
Postby Ira » Mon Jun 26, 2006 8:13 am
I figure that I'll look for a fabric I like, buy a half-yard, contact cement it onto a small piece of luan, let that dry, then varnish to see what happens to it. I'm sure the varnish will really darken it, so I gotta look for something that's predominantly light.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby doug hodder » Mon Jun 26, 2006 8:14 am
Ira...that would work really well...but I would do a test first... lay fabric directly on the wood, no adheseive on it...and brush it with varnish..see if that works, I would think it would soak through and adhear...when doing the sides I'd spray varnish on the wood out of a cheap spray can...use that as a glue to stick the fabric to...after you get the fabric positioned, brush on the heavy stuff to protect the fabric...just my thoughts on it. and this is very typical as to how to put fiberglass on the hull of a boat...although I lay my cloth dry and squeege the epoxy into the fabric...same technique however...Doug
Postby Ira » Mon Jun 26, 2006 8:15 am
Hey, great idea, Doug! Just use the spary varnish as the adhesive!
Another edit:
What do you mean cheap spray can? You mean just buy spray varnish, right? Like they sell at art stores?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby doug hodder » Mon Jun 26, 2006 8:18 am
You could also try using a lacquer Ira...you can get them in crystal clear...but they typically aren't made for exterior uses, unless you get the automotive stuff...like Krylon in a can...just read the labels...and I say "cheap spray can" as you don't need really good stuff...just enough to hold the fabric in place till you can paint it out with your top coat...Doug
Postby Ira » Mon Jun 26, 2006 8:35 am
Hey, I'm excited about this--there are some cool fabrics out there!
I'll just get a can of spray varnish from the art store. Also, this should be fairly easy trimming the fabric out around any corners.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby cracker39 » Mon Jun 26, 2006 8:43 am
Why not use the Minwax Polycrylic clear gloss? That's a water-based polycrylic finish that is said to be crystal clear. It may not come in a spray can, but can be brushed on for the base adhesive coat.
Dale
cracker39
Images: 233
Postby doug hodder » Mon Jun 26, 2006 8:46 am
Good idea Dale...I don't use it so it didn't even cross my mind! Doug
Postby Ira » Mon Jun 26, 2006 9:28 am
The thing is, I would want something REALLY thin for the base coat. There's going to be some awkward trimming with scissors/a blade, and I don't want anything too gloppy that'll get on the fabic surface before I'm really ready to apply it.
I'll get a can, and do a test with both.
But are you saying that this stuff ALONE may do it? That it's gonna soak through anyway to the surface?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Jiminsav » Mon Jun 26, 2006 9:58 pm
Ira, glue it down first..if you spray enough stuff to soak through, it will run down the sides like a waterfall.
Jim in Savannah
Jiminsav
Images: 40
Postby Ira » Tue Jun 27, 2006 7:00 am
Jiminsav wrote:Ira, glue it down first..if you spray enough stuff to soak through, it will run down the sides like a waterfall.
That's what I'm thinking--get it on there and then use the Poly. Otherwise, it's gonna be a mess.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby GeorgeTelford » Tue Jun 27, 2006 7:05 am
Hi
or what about....
spray the wood to seal it and provide a "glue" to hold the fabric in place, then spray the outer surface to seal.
GeorgeTelford
Postby Steve Frederick » Tue Jun 27, 2006 7:25 am
3M #77?
Spray the wood, apply fabric, then top off in varnish??
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Ira » Tue Jun 27, 2006 8:13 am
Steve Frederick wrote:3M #77?
That's what I'm thinking. The 3M will hold it well. Just think that the Polycrylic might be a better coating though.
Here we go again!
Ira
Forum Storyteller
Images: 118
