I went to mount my windows in the trailer last night and found that the small lip that the inside trim ring should screw in to wasn't very big. The screws just turned in the slot and made a big hole and didn't hole for nothing. So, I ended up drilling holes in the window frame and after applying the neoprene gasket strip material , set the window in and screwed it to the trailer wall with a bunch of small screws. It seemed to hole ok and it sucked the window in tight to the wall. I think Madjack had this similar problem and this is what worked for him. I may still put the trim rings inside the same way just to finish the inside cutouts for looks and giggles. I don't have any pics (sorry
) but i did get the windows in and sealed. I get to pick up some carpet tonight after work and try to get that in tonight. It's almost done! Just some "LITTLE" things to finish up. And we all know what that means, don't we. The little things never seem to end. THanks for all the info and support on this forum. WHat a great bunch!
Oh, and pics will follow, I promise.
