bronco wrote:madjack, i have a welder here at home could i just weld a piece of steel in the u-shape void and drill the correct spaced holes so i would be able to flip it back over and get the correct camber back and still be above the springs?
Nitetimes wrote:I would recomend carefully grinding off the old ones and using them, that will keep your axle spaced right from front to back. Those seats are not expensive tho, it would be much easier to get another set and just leave the old ones on it.
By the way don't weld on the springs!
