by doug hodder » Tue Jul 11, 2006 9:48 pm
Jeff...ideally vinyl graphics prefer flat smooth surfaces, but if you really burnish them down well, with a rubber squeegee they should stick for you, hard plastic squeegee on smooth surfaces, rubber on a dimpled surface...just for grins, go by a local sign shop that cuts vinyl and ask them if they have a scrap of vinyl that you could do a test with...clean off the area really well and wipe some vinyl down on it and see how it works...also, vinyl can be installed wet or dry...wet meaning using a little water with a couple of drops of liquid soap in a spray bottle...this method allows you to position, lift and move the vinyl before you squeegee it down...when you do dry...it better be good from the get go...worked in the sign industry...just my experience...Doug
doug hodder on Wed Jul 12, 2006 12:03 am, edited 4 times in total.
