There's next to zero stress on moderately curved 1/8" plywood. It's all gone once it's laminated with another sheet on top.
Yes, but any sags or non-uniform curves will have to be dealt with to get a nice result before the second layer goes on and or more supports to maintain the correct shape. It also means cutting two pieces to fit instead of one and trying to work around the rest of the structure rather then in isolation during lamination. Plus, it might be possible to use a vacuum to make the strongest laminations possible by working with one part at a time. May be a case of "six of one, a half dozen of the other" but at the moment I think it will be easiest to get the best results by doing the curves off build then installing.
We tend to follow the Keep It Super Simple methods
I usually start from the design objective side and work back to how to do it the easiest way. My objectives are to be big enough to act as support for a family of 6, comfortable sleeping surface, fast setup (lunch on the run, getting to campgrounds late...), be the most effecient towing (we covered thousands of miles on every trip so far and gas is not getting cheaper), be the most stable and secure on the road (my wifes driving scares me already w/o towing anything). These are the whys of the choices I've been making in this plan.
Thanks,
Beej
