- This sketch is from a series drawn in the winter of 2006 under the Northern Lights in a small cabin on a ridge above Goldstream Valley, Alaska.
- The plan envisioned a light weight chassis, riveted aluminum cabin construction, strength, durability, low maintenance & a reasonable aerodynamic profile to be pulled with a small car.
- Well, I finally made the mechanical drawings & built it in Greenville, Michigan. It came in at 525#. 900# GVW. Allowing 375# for gear. Hitch weight 90#. Ride height 10". Tire track 62".
- Overall length 10'-4", width 5'-9", height 5'
- Interior length 80-1/2", width 45-1/2", height 42-1/2", footwell height 20"
- Door with slider window 26"x36". Window with slider 30"x20". Tailgate 18"x46".
- Edit: added mechanical drawings on page 4.
- Sharing the experience:
