revamping the weekender
Postby dovaka » Tue Jun 05, 2007 11:17 pm
volfanatic72 wrote:I've been playing with the original design too...
Any negatives with making the front and rear angles the same???
i dont think it looks bad i just needed more room in mine as i essentially have no room in the tow vehicle so were making the tear with enough storage to be self sufficient of the tow vehicle
dovaka
Images: 6
hELLO
Postby Jeeper92 » Tue Jul 24, 2007 10:34 pm
Did you ever start building that weekender?
Jeeper92
Postby mikeschn » Wed Jul 25, 2007 3:24 am
Okay, one Airdrop forum, coming up! :rofl: :rofl: :rofl:
mikefowler wrote:
no my plan is to save weight by having it be sled mounted
Heck I would go this direction and "Go with the flow!"
Maybe Mike can start a NEW forum - For "AIRDROPS"
:lol:
The Design Looks REALLY GREAT - All kidd'in aside
Postby dovaka » Wed Jul 25, 2007 8:01 am
yes we did start building i got as far as the frame and put a deck on it then ran out of time from doing fireworks "i work for a commercial display company" so hopefully i will get to it again soon
dovaka
Images: 6
Postby Joanne » Wed Jul 25, 2007 8:16 am
Strike what I wrote before, the front of mine is 52 degrees and the rear is 45 degrees. The top of the doors are cut at the same 52 degree angle to complement the look. Sorry for the previous inaccurate information.
<<I used the same angle on mine, but cut the rear "deeper" than the front. I did this because I liked the look better than chopping the front and back exactly the same. The doors are cut at the same angle to complement the look. >>
I played around with graph paper until I found the angle that I thought looked the best.
Joanne
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
joanne
Postby Jeeper92 » Wed Jul 25, 2007 10:16 am
where did you get the diamond plating on the side of your dawg, i think it looks really sharp
Jeeper92
Re: joanne
Postby Joanne » Wed Jul 25, 2007 8:31 pm
Jeeper92 wrote:where did you get the diamond plating on the side of your dawg, i think it looks really sharp
Hey Jeeper,
I went down to a local steel supplier and asked if they carried any aluminum diamond plate. It was a bit over $100 for the 4x8 sheet and another $30 or so to have it sheared. I had them cut 5 strips, each 3 inches wide from the long side. The remaining piece went across the front. I think it dressed up the trailer a lot and having it on the front will reduce chipping of the paint.
Here a picture that shows the front and sides.
Needless to say I'm not the first to use diamond plate and I won't be the last, but if it's a "off road" look you are trying to achieve it really does the job. If you have diamond plate on your tow vehicle, then it visually ties the two together.
Joanne
P.S. - I draw the line at putting diamond plate on the inside of the trailer!
Joanne
Queen of Cast Iron
Return to Member Designs
