how bout motorcycle fenders on a td?
Postby goldcoop » Sun Jan 15, 2006 12:08 pm
madjack wrote:Jim, without having the fenders in hand it is hard to say BUT they should prove no more poblematic than the FG fenders from Grant, RW Johnson, etc...I like the fact they can be had in wider widths than those fenders and are cheaper to boot!!!! I just wonder if they are long enough across the bottom line
MJ-
It says they are 44" long over the arch, wonder what that means!
The cost of others was what prompted the thought!
Makes you wonder what they REALLY cost!?
Coop
goldcoop
Images: 32
Postby Kevin A » Sun Jan 15, 2006 12:19 pm
MJ-
Coop
I'm assuming they are measuring from the front lip of the fender, over the top of the fender to the rear lip, but you know what they say when one assumes things. ;) :lol: :lol:
Kevin A
The other guy
Images: 289
Postby madjack » Sun Jan 15, 2006 12:44 pm
Kevin, like you I am assuming the same(and face the same predicament) if you double that #(if they are a full half circle) and divided by Pi you get 27+ inches for straight line length, which would work depending on tire size
p.s. I sure wish someone would buy a pair and try 'em out...hint, hint, hint
Return to Member Designs
