Russ in California wrote:Just a bit of info. In Larry Sorrensen's Outback TD, well tested and beat to p*ss on the roads and trails in Mexico, used a 3x3 on his tongue.
"I'm just sayin..."
There you go...
Steve F wrote:Russ in California wrote:Just a bit of info. In Larry Sorrensen's Outback TD, well tested and beat to p*ss on the roads and trails in Mexico, used a 3x3 on his tongue.
"I'm just sayin..."
There you go...
Except that is a straight tongue not an a frame The A frame in 2X3 will be stronger than the straight tongue in 3X3.
Cheers
Russ in California wrote:Why do you suppose he went with the straight tongue?
stomperxj wrote:Russ in California wrote:Why do you suppose he went with the straight tongue?
Because he didn't research on how to build a frame properly? That's my guess ...
Russ in California wrote:Steve F wrote:Russ in California wrote:Just a bit of info. In Larry Sorrensen's Outback TD, well tested and beat to p*ss on the roads and trails in Mexico, used a 3x3 on his tongue.
"I'm just sayin..."
There you go...
Cheers
Steve F wrote:
It can give more room for tight turns etc before it hits the tow vehicle, other than that and a weight saving I cant think of any real benefit. I like the A frame as it is stronger by design and I plan to mount a tongue box on it for storage as well, this is harder with a single tongue and defeats the added benefit of more turning room that the single tongue offers anyway.
Cheers
wlivesey wrote:What would you recommend for framing in the roof and side walls? I would like to have 1.5 in. of insulation if possible.
I've looked through Larry Sorensen's Outback TD and see that he used 3/4 ply for his uninsulated walls. I want my walls well insulated but I don't think I should compromise strength.
All the framing also makes my build seem much more complex.
Thanks again,
Bill
