Sidewall questions
Sidewall questions
Postby mandy » Tue May 20, 2008 11:35 pm
Hi everyone,
I was wandering around the forum and saw lots of examples of sidewall frameing. I saw that a lot of people use pocket hole jigs and screw all the framing together then cut to shape. I have also seen some cuting the whole frame out of 3/4 ply. What are the advantages and dis-advantages of each type?
Thanks
Mandy
~Plato~
mandy
Images: 86
Postby asianflava » Tue May 20, 2008 11:55 pm
I used 1X framing held together with biscuits, then I insulated it with rigid insulation and used 1/8in ply for both faces.
1X lumber is 3/4in thick so is the insulation, 3/4in ply and furring strips aren't really 3/4in.
asianflava
Re: Sidewall questions
Postby Nitetimes » Wed May 21, 2008 12:31 am
mandy wrote: What are the advantages and dis-advantages of each type?
Thanks
Mandy
It's really personal preference. I think th weight probably comes pretty close to the same I just found it easier cutting out the sheet of ply for a frame, didn't have time for gluing all the boards together and such. Less worry of it coming apart while you're building too.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby bobhenry » Wed May 21, 2008 7:02 am
I used the whole sheet and I can hang a picture anywhere I want.
Postby Miriam C. » Wed May 21, 2008 7:26 am
I used 3/8" ply and 1" framing with the curves kerfed. Easier for me because I didn't really think I could cut the curves.
If you have a router then you can pre-make the frames and use the router to match your sides. However---screws and routers don't mix so glue and take the screws out before cutting. :thumbsup: This is the way I will do the next. :thumbsup:
Postby mandy » Wed May 21, 2008 10:57 am
Rich do you have any pics of the frame how did you cut it out?
Does any one have pics of their framing they want to share?
Thanks
Mandy
~Plato~
mandy
Images: 86
Postby toypusher » Wed May 21, 2008 10:59 am
I built my sidewalls (including the inside skins) lying on the trailer and then put them up. Pictures in the link in my signature.
toypusher
Images: 324
Return to Member Designs
