Box Kite Phase III begins
after a wk or more on the road there is lots that you do not know about your trailer until you really sleep in it.
the Doors work well and will be replaced in time.
I was going to move a small dresser into the trailer but found it to heavy.
after about halfway on the trip Lucia said the clothing part should be on top.
This trailer has a hatch at the back but not curved like at TD but straight down and square.
I use two PCV pipes with alumimum conduit piipe inside that slides up and and has holes in it to put in a pin to make it higher and and hold up the hatch.
I had to edit after looking at sometime later and had know idea what I was saying sorry if you got confussed I will try and explane my projects better.
