PaulC wrote:I built mine using 50mmx50mmx3mm(you can convert that Everyone down here called it the tank. Final weight was just on 600kg(about 1200 in your language) Way too heavy. Number 2 was built using 50x25x3. Beautiful.
Steve F wrote:4" tubing is indeed massive!!! 4"x1"?
I also thought about sliders but went against them because of the weight and what I thought might be the hassle of climbing over them to get in and out. Ended up making sure the walls sat on top of the frame so the frame acts as a slider and then used aluminum diamond plate to protect the lower sections of the walls.
wlivesey wrote:Steve F wrote:4" tubing is indeed massive!!! 4"x1"?
I thought the sliders might make it easier to get my kayaks on and off the roof - also with my external fenders I thought they might need a little
protection from rocks etc. That being said, they would add weight, expense and make getting in an out of the trailer more difficult.
Maybe move the wheels inside the chassis??? That would make for an even wider trailer since I want to keep my queen sized mattress.
