xrover wrote:Generator by your head? Ouch! Might was to consider moving your bed and kitchen, or locating the generator near the kitchen where the most power is required.
stomperxj wrote:I like the profile. It sure is wide though. Whats your tow vehicle?
S. Heisley wrote:Nice! Both the TV and the camper layout! Looks do-able. The only thing I see is what you probably already know: You'll most likely need brakes on your trailer.
Happy Building!
Trackstriper wrote:You'll get different opinions on this but I'd vote for a quick answer of 12"...
One of the things that you have to plan out is your running gear. With a trailer that size I'd go with 15" wheels and be done with it, yes 14" will also carry the weight just fine. I have a 6x12 cargo trailer and it has 2"x3" frame rails, 4" drop 3500# axle located over the springs with fairly short spring hangers....12" under the frame. That's about as low as they could get it with standard hardware...and the axle travel is only about 1-3/4" before if hits the frame, which I'm not totally wild about, but I guess it works.
wlivesey wrote:I know, the trailer is wider than I would like...
I'm thinking that I will need to recess the wheels underneath the body.
brian_bp wrote:...the mass is out near the ends, which is the standard formula for an unstable and difficult to control trailer.
