The Astroshack - A Mobile Observatory
My goal is to build a trailer that will store and haul my telescopes which will make it easier to spend more time under the stars. The scopes are a pain to load in a pickup, and one is a 12" Newtonian that's about the size of a water heater. Unfortunately that negates the classic teardrop galley design!
As a camper, it will primarily be used for overnight stays. Leave after work on Friday, set up at dusk, observe until the wee hours, sleep for a little while, pack up in daylight and come home. It must be boondock-friendly, so an AC isn't on the list. It might be used for the occasional weekend trip. We have a pickup, so there's space for coolers and a camp stove elsewhere.
While some of the classic designs with cabinets, water, galleys and other designs are something I really like, it's just not necessary with this project. I'm looking for something that's a step up from a tent.
I'm tall and my wife is cold-natured. I'm looking for as much space as possible and it will be insulated.
I've sketched it out with only one door with a window. To me that means only one set of seals to go out and it's dark on the inside for sleeping in. I'll probably make it an opening window for fan circulation.
I'll wire it for 12v battery and power strip for shore with a battery maintainer. LED white and red lights as needed inside and out.
I've attached a cocktail napkin sketch. I'm thinking about using a 4x8 Tractor Supply trailer. The sides are radiused on the front to cut on a little drag and take some pressure off the front.
Let me know what you think and thanks for your time!
