as I mentioned in my Newbie-thread, I want to design a trailer that is light enough for our 2cv to tow (400 kg / 881 lb breaked). On the other hand, I (read: we two) want a full size bed (I guess that what's you call it - 1.4 x 2 meters which is about 55x78 inch?). Which gives us a "about 5 feet" width and, because we want a little bit of galley, 9 or 10 feet length.
For reasons of "design / look / feel", I thought it would be nice to meet the 2cv's measures and profile.
A 2cv is 148 cm (58 1/4 inch) wide, so we try to be in the shade of that - if we go 4'9" or 4'10" we should make it. Also, that gives us some play with plywood and aluminium sheets, since they can be had in 150 cm width.
The total length of a 2cv is 383 cm (12'6"), so I hope to get the length of trailer plus tongue to that.
Total height of a 2cv is 150 cm from street to rooftop (without payload), I guess we'll stick to the regular 4' height of most trailers, maybe we'll add a pop-up-roof window/top or a foot well to be able to sit in it.
My favorite designs are the Grumman and the Cub. Although a DA would be great for design / profile reasons (slight detour: a 2cv is called Ente = duck in Germany, so the rear of the design can reasonably be called a Duck's a*** or maybe a "Bürzel" (birds-el) which is hunter's speak for the same body part).
Okay, I'm an absolute newbie in terms of CAD or similar, even not good with a pencil and paper. Much better in thinking and dreaming and envisioning.
Here's an Internet picture / "blueprint" of the Duck:
I'm sorry that the dimension figures aren't readable... But I do have several books plus a live Duck at home (quack, quack), so if you need some, I'll get them out (or tape-measure myself).
So, if anyone can combine the flat falling trunk hatch and upswept bottom line of the Duck to a Grumman or Cub design, I would be ever so grateful. Maybe I'll even try to realise the tilted side walls...
